iClone3 Max Plug-in Quick Guide
Install the Plug-in
Quick Steps
UI Overview
File Types
Model and Material
Animation
Non-Human Character
Bounding Mesh
Sky
Head Morph
Install the Plug-in
1. Extract the zip file to a temporary folder
2. Put the "RLMaxExp" folder and iClone3MaxExp.dle into 3ds Max "plugins"
There are 4 files contained in this folder:
    Profile_Human_Full.prf
    Profile_Human_Gesture.prf
    RLBoneFullG1.VNS
    RLBoneGesture.vns
3. Put IMGRT.dll in 3ds Max installation folder, the same place where 3dsmax.exe is located.
Note: Microsoft Visual C++ 2008 SP1 Redistributable Package (x86) and the latest DirectX End-User Runtimes should be installed before running the plug-in. If you have iClone3 installed, you already have them in the your system. To get the installer, please visit Microsoft Download Center.
Quick Steps
To export iClone3 data from 3ds Max, do the following:
1. Have the model/scene ready in 3ds Max.
2. From the File Menu, choose ¡§Export¡¨.
3. Change the file type to ¡§iClone3 File¡¨. Click "Save" button and the export panel shows up.
4. Select file type, set the export options.
5. Click "OK" button to export the content.
6. Import and check the content in iClone3.
UI Overview
The exporter interfaces are divided into the following groups:
Export Content group:
For selecting file types, assigning the file name and the destination folder. There are also options for data optimization, exporting Character Studio BIP animations and hand gestures. See Optimization and Character Studio session for more details.
Information group:
This is where you can mark your work. This author information will be embedded into the content file for later retrieving .
Thumbnail group:
Auto Generate: Use a default image as the thumbnail.
Assign Thumbnail Images: Specify a thumbnail image to be used within iClone to identify your content.
Texture Size group:
No Limit: Allow the texture to be whatever size you have created.
Maximum Texture Size: Limit the maximum size of the texture maps you have placed on the objects.
File Type Specific Option:
File type can expand to show some specific files. There are content types which may have animations, including "Character Animation", "Non-Human Character", "Accessory" and "Props". See Animation session for more details.
Note: These export settings will be kept when you save the max file.
File Types
You may create and export these iClone3 contents from 3ds Max:
Standard Character:
iClone3 supports G1, G2 and the newest G3 characters. These Standard Characters are created by the production pipeline and specific rules and are full-featured. You can apply motions, facial animations, switch body parts, modify head shapes, assign Personas to iClone Standard Characters. Please refer to the white paper ¡§Creating and Exporting Characters for iClone¡¨ chapter for more details on character creation.
Non-Standard Character:
They are character models skinned to RL bones but not following the production pipeline completely. Non-Standard Characters have limited features.
The following table lists the available features of different type of iClone3 Characters.
  Standard Character   Non-Standard Character  Non-Human Character
Persona   ¡³ ¡³ ¡³
Adjust Proportion   ¡³ ¡³ ¡³
Apply Motion   ¡³ ¡³ ¡³
Edit Motion   ¡³ ¡³ ¡³
Body Part Switch   ¡³
Add Accessory   ¡³ ¡³ ¡³
Edit Face   ¡³
Facial Animation   ¡³
Hand Gesture  ¡³ ¡³
Skin Texture   ¡³
Cloth Texture   ¡³
NEW Character Animation
Now you can create character animation in 3ds Max then export the animation as iClone3 Motion clip.
The skeleton to be animated can be either RL Bones or Character Studio Bip Skeleton. Since Bip Skeleton is well rigged and easier to animate, we recommend you use it to create iClone Motion. See Character Studio session for more details
NEW Non-Human Character
Non-Human Characters are characters that skinned to any skeletons or bones other than iClone standard RL Bones. The skeletons can be constructed with hierarchical mesh models, standard bone system or dummies, in any bone structure like a horse, a bird or even a dragon. See Non-Human Character
Accessory
An accessory can be attached to any bones of an iClone Character and saved with the character as part of the outfit. The mesh models and animations can be exported with the exporter.
Props
In addition to the still Props & LiveProps in iClone2, the new iProps (interactive Props) are introduced in iClone3. iProps are props that have interactive behaviors, like doors can open, chairs to be sat on, or cars that can be gotten into and driven. Similar to how Persona defines the character behaviors, the interactivities of iProps are defined with Dramascript.
Please visit iCloneWiki to know more about iProps and Dramascript.
NEW Terrain
3D Scenes in iClone2 are now separated into two types of contents: Terrain and Sky. iClone3 Terrains are special mesh surfaces which characters can walk on, props can move along, trees & grass can be planted on. You may assign a simpler model as a ¡§bounding mesh¡¨ for a complex terrain to help speed up the rendering performance. Bounding meshes can also be used to define the impenetrable wall in a scene like shown in the following figures. See Bounding Mesh session for more details.
NEW
Sky
iClone3 Skies are domes or hemisphere models enclosing the whole scene. Skies have their special setting related to lighting and fog effects.
See Sky
NEW
Head Morph
You can create custom head morph models by editing the shape of the head base model.
See Head Morph
Model and Material
This session describes supported model and material format you can create in 3ds Max then export for iClone3.
Mesh Model
The exporter can process all kind of mesh models including primitives, polygon meshes, quad meshes and triangle meshes. However, they will be all converted into triangle faces in iClone model format. It's always a good practice to convert the model into Editable Mesh or Editable Poly before exporting.
Material
iClone3 support the following material parameters and map types:
Material Type Basic Parameters Maps
Standard Material
Multi/Sub-Object
Blend Material(4 maximum)
Ambient Color
Diffuse Color
Specular Color
Self Illumination
Opacity
Specular Level
Glossiness
2-sided
Diffuse Color
NEW Specular Color
Glossiness (for Glow effect)
Opacity
Bump/Normal
Reflection
Multiple Map Channel (4 maximum)
NEW Coordinate Offset & Tiling
In the image below, the corresponding settings in 3ds Max Material Editor are highlighted.
Note: Map coordinate offset & tiling takes effect only under Vertex and Pixel shading in iClone3.
Animation
In addition to transform and UV animations supported by iClone2, the new exporter can export material animations edited in 3ds Max.
The following table shows the supported animation types.
Type
Parameter
Transform Animation
Rotation
Translate
Scale
NEW Material Animation
(Props & Accessory only)
Ambient color
Diffuse color
Specular color
Shininess
Shininess strength
Self Illumination
Opacity
Opacity falloff
Map Amount
UVW Map Animation
UVW Data
 Transform animations and UV animations are exported as animation clips which are embedded data within or separate files from the model files.
Material animations are in the form of material keys and can be modified in iClone3.
The material animation sample shown below can be found in the Sample File folder.
Note:
The length of the material animation is the same as animation keys set in 3ds Max.  To make it longer, copy and paste material keys along the timeline as long as you need.
"Character Animation", "Non-Human Character", "Accessory" and "Props" are content types which may contain animation data.
When one of them is selected, the animation export option panel is expanded. There are two option groups
Export Option
All: Export the model with animation clips embedded within. This option is enabled when the file type is Prop or Accessory.
Geometry Only: Export the model data only.
Animation Only: Export only the animation files by the clip list definition.
Animation Clip:
This is where you define the animation clips to be exported.
Name: Double-click the field to edit the clip name. The name typed here will be the file name of the exported prop/accessory animation file (*.iAnimn) or character motion file (*.iMotion).
From/To: The ¡§From¡¨ and ¡§To¡¨ fields define the frame range of the specific clip. Double-click the fields to modify the frame number.
New: Add a new clip in the list with default settings.
Remove: Remove the selected clip from the List.
Save: Save the Clip List definition as an ASCII file.
Load: Load an external Clip List definition file.
Import Animation
To Import Character & Non-Human Character motions, go to Motion Modify panel, press Import button to import the motion file.
Or go to timeline, expand Character Perform track, right-click on the track, select Import from the pop-up menu to locate and load the motion file.
To Import Prop or Accessory animations, go to timeline, expand Perform track, right-click on the track, select Import from the pop-up menu to locate and load the animation file.
To Apply the embedded animation clips, right-click on the prop or the accessory to pop up the Right-click Menu, move the cursor to Perform entry and select one of the embedded animation clips.
Or go to timeline, expand Perform track, right-click on the track, move the cursor to Perform entry and select the clip to be applied.
NEW Animation Key Optimization
The exporter will sample the animation frame by frame without key optimization. This keeps the animation intact to the original but the price is generating oversized animation data, especially when the animation curves are mostly linear. Animation key optimization can remove the unnecessary keys and also keep the result as close to the original as possible. To optimize the exported animation data, check the Optimize option to activate Animation Key Optimization while exporting.
To modify the optimization parameters, click the Optimize button to open the Optimization Options dialog box.
Sample Rate: Set the sample interval for sampling animation keys. The more the interval frames, the less key will be sampled for difference analysis.
Threshold:
Set threshold value for R (Rotation), T (Translation), S (Scale) and P (other Parameters, like material animation keys) difference analysis. The larger the threshold value, the less key will be reserved. Setting the threshold 0 will remove only the keys along linear animation curves and preserve the animation result.
Non-Human Characters are characters that skinned to any skeletons or bones other than iClone standard RL Bones. You may Rig the character with any bone structure constructed with 3DS Max bone system, hierarchical mesh object, even helpers like dummies.
Notice: Never use mirror to make the opposite bones of a Non-Human Character. It will scramble iClone3's IK & Mirror mechanism.
Once the character model is ready and exported as an iClone3 Character file (*.iAvatar), you still need an ini file to provide more character information for iClon3 to make it a Non-Human Character.
Here is the content of the ini file:
[Bone]
RootName=RootBone    // The name of the character root bone
LengthBone = 0             // Define the bone axis, 0 = X, 1 = Y,  2 = Z
[IKTypeMap]                // Define Types of IK control
RootBone=1,0               // For the root bone and fixed bones, give the value 1,0
Pelvis=1,0
Spine01=1,7                      // For the other animatable bones, give the value 1,7
[IKConstraint]                // Set rotation constrain for the bones. This setting takes effect when the "Constrain" option in iClone3 Edit Motion Layer panel is on.
Bip01=(0,0)(0,0)(0,0)    // The format is: Bone Name = (X min. angle, X max. angle)(Y min. angle, Y max. angle)(Z min. angle, Z max. angle)
Pelvis=(-5,5)(0,0)(-5,5)  // The initial angles of the constrains are the bone angles of the skin pose of the character
Spine01=(-10,10)(-60,60)(-40,40)
[MirrorBone]                // Define the opposite bones so the "Mirror" option can take effect while editing motion layer.
L Clavicle=R Clavicle
L UpperArm=R UpperArm
L Forearm=R Forearm
L Hand=R Hand
Only the [Bone] part is must. The IK & Mirror function will be just disabled if [IKTypeMap], [IKConstraint], or [MirrorBone] definitions are not given. Name the ini file the same name as your character (e.g. if the character file is Dragon.iAvatar, the ini file shall be Dragon.ini ), and put it in the same folder of the character file. When the Non-Human Character is loaded in iClone3, the ini will be parsed and embedded with the character. You can find a sample ini file (CS_Character.ini) for Non-Human Character in the Sample File folder.
Convert Character Studio BIP skeleton into iClone3 Non-Human Character
Since iClone3 doesn't support Character Studio Skeleton directly, to make a Non-Human Character from a BIP rigged character, you have to convert the BIP skeleton into max bones first. Before you start, please go to Autodesk  FBX page to get the latest version of  FBX exporter and install it.
Note: Please use the version 2006.11.2 which you can find in FBX "Plug-in and Converter Archives" pages.
Here are the conversion steps:
1. Load the BIP rigged character in 3ds Max.
This monster model is downloaded from 3DRT free download Page.
2. Choose "Export" from File menu.
3. Select Autodesk FBX file type, press "Save" button.
4. Use the following setting. Export the FBX file containing the model and all animations.
5. Reset 3ds Max, Choose "Import" from File menu, and select Autodesk FBX file type.
6. Use the following settings for importing the FBX file.
7. Now the BIP bones are converted into Dummy bones.
8. To export it as a Non-Human character, choose "Export" from File menu, select Non-Human character file type.
9. Select Geometry Only in Export Option and press OK button to export the rigged model.
10. Execute Export again, this time select Animation Only edit Clip List as describe above, then press OK button to export the motion clip files. These motion flies can be imported and applied to this specific character in iClone3 with Motion Modify panel.
11. Prepare the ini file for this Non-Human character. The sample ini file (CS_Character.ini) is ready for any Character Studio BIP character with skeleton root BIP01. Just rename it the same name as the Non-Human character file and put them in the same folder.
12. Run iClone3, go to Avatar Modify, import the Non-Human character.
13. Go to Motion Modify, press Import button to import the motion clip files, or press Edit Motion Layer button to start motion editing.
NEW Bounding Mesh
Bounding meshes are mesh surfaces which define the boundary of a model for alignment and collision detection. They are usually simpler versions to the target models, e.g. a box bounding mesh for a car model. In iClone3, bounding meshes of Props are for collision detection, and those of Terrains are for both collision detection and terrain following.
To assign a bounding to a prop or a terrain model, follow the name convention below
Object Name_Boundingmesh
For example, the bounding mesh model of an object name "Terrain" should be name "Terrain_Boundingmesh"
Terrain bounding mesh is always invisible in iClone3.
To examine Prop bounding mesh, switch the Display into Bounding mesh mode.
In this example, the bounding mesh is a simple sphere enclosing the Teapot.
Note:
If you don't provide bounding meshes while creating Terrains, iClone3 will use the mesh of Terrain itself for alignment and collision detection. In the case of Prop, iClone3 will generate a bounding box for the Prop without bounding meshes assigned.
NEW Sky
Create an iClone3 Sky is simple. Here is one of the procedures:
1. Run 3ds Max. Create a GeoSphere at the origin (0,0,0), set Radius 5000, Segments 4.
2. Add Normal Modifier to flip normals.
3. Apply a panorama sky map to diffuse map slot, set Self-illumination 100.
4. Choose "Export" from File menu, select Sky file type and export it to the Custom Sky folder.
    C:\Documents and Settings\All Users\Documents\Reallusion\Custom\iClone 3 Custom\Sky
5. Run iClone3, go to Sky Content Manager Custom tab, apply and check Sky On.
You can find a sample sky model in the Sample File folder.
NEW Head Morph
To create a custom Head Morph, do the following:
1. Load the head base max file Head_Base.max from the Sample File folder. The head base is an Editable Poly model.
2. Switch to Sub-Object editing mode. You may use any polygon modeling tool to modify the head shape. But keep the following things in mind:
    (1) Don't modify the pivot of the head.
    (1) Don't add or delete any vertex, just edit the shape.
    (2) Keep the shape and position neck section loop as close as the base model.
3. Choose "Export" from File menu, select Head Morph file type and export the model.
4. Run iClone3, go to Face Modify, select Head category then import the Custom morph model you just exported. Drag the Weight slider to check how it works.
