Continue Building the House 12. Rotate view to the back of the house and use the Rectangle Tool
12.(b) Use Push/Pull Tool
13. Use Line Tool
14. Use Push/Pull Tool
¡@ 15. Time to start using what you have learned previously. Use the Rectangle Tool and the Push/Pull Tool to draw and raise the back porch:
16. Use the Circle Tool to draw a circle on the underside of the roof overhang then use the PushPull Tool to pull it down to the porch surface. Add the Door and Window components as shown in the image below (a three window component was used in this example):
Create Simple Model - SketchUp
