Hints & Tips |
Case1: The imitation of
real material |
Learn it in five easy steps.
There are different degrees of reflection toward light as
a result of the attribute of the material itself. We can modify
the contrast of reflection map through the function of material
in iClone to verify the degree of reflection on the surface
of an object while rendering. As long as the proper material
is selected, any real object can be created.
Get the trick |
Case2: How to make your
warrior fight |
You can build up
a fantastic epic by editing a series of spectacular fighting
motions. Follow the 11 steps to make your character vigorous
and nimble. You can have your character bob, brandish, chop,
and bedazed.
Get the trick |
Case3: Apply your particles
to cool motion |
If we get fantastic
particles, when will we apply them to our video works? Apparently,
appropriate action or movement is still crucial to optimize
the performance of particle works. See how it was done.
Get the trick |
