Tips of the Month: 11 Steps to release power with motion
Example: Apply your particles
to cool motion
Note.
The position of particles will be placed in “Accessory/Prop”
in iClone 1.52, as to iClone 2.0 and above, there will be a new
category of panel for them.
Click to see the outcome
1. Select an appropriate Avatar in iClone
2. Switch to “Animation / motion” and select the according
motion
In this case, we would like to let the sorceress raise her left
hand,
draw circles and release particles after turnaround.
3. The details of the geste is also important when releasing powers,
there, switch to “Animation / hands / Modify” and open
“Timeline”.
4. Right click the track of “Left Hand” and select the
geste what you prefer to in Timeline.
5. And then, we need attach the particle (fire) to the finger of
left hand and make residual images while she draw the circles. Switch
to “Avatar / Accessories / Template” and find “Magic_Fire”
of “Effect Pack / Magic effect”. Now, you can click
“play” to see different effects?
6. Switch to “Scene / Props / Template” and add “Magic_
Spark” of “Pack / Magic effect”.
7. And the position of “Magic_ Spark” will be unanticipated
(that’s because the particles are put under the category of
“props” in iClone 1.52), therefore, we should set key
to offer moving path for the particle by Timeline.
8. Switch to “Modify” of “Prop” (iClone
1.52) and open Timeline.
9. In this case, the “Magic_ Spark” won’t appear
in the previous parts of motion, so we need to move it offscreen
in the first frame.
10. The “Magic_ Spark” remains the same position at
frame 221 as frame 1, and it shifts to avatar’s finger at
frame 222. (We should test the timing to and fro to unleash according
to different gestes.)
11. Finally, set the end key of “Magic_ Spark” for its
moving path at frame 290, and click “play” to see the
result of particles in Real Time.
