Create LED Sign
Add the UVW Map Modifiers
  1. Select the Sign Plane
  2. Select the Modifier Tab on the right menu of the 3ds Max interface.
  3. Select the UVW Map modifier which adds this map to the modifier stack.
  1. Change the "Map Channel" to "2" for the Diffuse Map.
  1. Do 1, 2 & 3 again to add a second modifier.
  1. Set the selected "Map Channel" to "1".
Create LED Sign
