Create LED Sign Color (texture) the Sign Background The background of the sign that the letters will scroll across will need to be a flat black instead of a glossy black so we will convert the sign exterior to editable mesh then select the sign background and color it with a flat black.
As an alternative you can create a flat plane the size of the
back plane and color it with the Note: At this point you may not be able to tell the difference in the back plane color and the sign exterior color either in the rendered image or 3D Max workspace. The difference shows up when imported into iClone. �@ Create LED Sign
